ca18detpowered »
https://forums.nicoclub.com/ca18detpowered-u48340.html
Sat Dec 16, 2006 7:47 am
yes im pretty sure it does. its got the same notch. You prolly just have to re-pin it, meaning using a small screwdriver, push the release thingys inside the hole the pin sits in,youll figure it out, its a beotch
and does it stutter up to 3k then pull hard after boost?
mine did that stutter bull**** too, so i got an safc......tried tuning, wasnt the problem. Turned out I had to get the safc to translate becuase of a slightly different maf signal.
i had to set maf in to 1 and maf out to 2
or vice versa..cant remember
