Well, the signaling for speedo is the same either way (although different body harnesses etc may run the wire through a different shaped connector or pin on it), I swapped my USDM cluster for a German one without any changes (240km/h = ~150mph max).
But yeah if you have a JDM car then uncut lower harness makes sense
