Because I know thisthemadscientist wrote:You have to be careful with blanket statements like "because this is bigger that is useless" You would find it cuts both ways should you stray into the SR20 home turf.
And the same kind of excessive dogma you are pushing about the larger ports is the same thing a guy with a 2 liter motor will say about your 1.8. The SR is bigger so your CA must be a waste of time. To use your own logicard wrote:edit: btw - i own ca18det and sr20de
do you see the irony?ard wrote:look at it from builders side - what setup would you use? what setup requires less money/effort?
Im afraid that you are the one that dragged the dead horse of ill informed opinion into this thread.ard wrote:it is brave to tell that there are no 8ports in UK since jdm car importers do their job as i understand difference is in stock head - to low diameter ports in 8port head called LOWport, and high diameter port head called HIGHport. logic?one sided view? maybe, but remember that there are 8ports and nobody uses it. why? the biggest part of imports in US is from jap. mainly lowports. don't you think that they are one side minded?
enough of kicking that dead horse.
themadscientist wrote:http://www.yellowmunsontuning.com/PT67CA18.htm
I just had to quote this rubbish again..ard wrote:i dont know what exact cfm 8runner begins to su$k horse di$k, but you can search at sxoc.com (uk biggest silvia community) for exact numbers etc.
8port runner has two narrow ports - one for low rpms (little diameter - you get better flow, better "air supply" (dunno how to write that in english)), on high rpm both ports are open to maintain the same air pressure and speed in runners.4port (highport) has 4 big ports - not very good air flow at low rpms, but you have no top end restrictors.read some theory about air flow, inertia and try to use your brain thinking about exhaust backpressure (the same air flow principles)
somewhere i had found flowrates of 8port/porter 8port/4port/porter 4port. ported 8port had few % better air flow than stock 4port. ported 4 port was unmistakable the best.
Indeed! I just bought two new ballbearing monsters for both my drag and my fun car, so why not add that to the equation . I'll let you know what I see when I see what I want to see .themadscientist wrote:you moving on that item we discussed dee?
Well boys and girls, I guess it's time for me to stop hiding and get those big HP cars I've been so slow at assembling assembled. Oh Yeah, they will be sporting tricked-out 8 port heads as well. Nissan designed them and I don't think the design was flawed. I love the design and we'll see how our numbers stack up against others'. Goal: Fastest FWD CA18DET powered B12 sentra in the world. I got the mph thing down being clocked at over 173mph a few years ago, so we'll see. My protege's goal: Sub 9 second passes in his CA powered S13 (Big goal),but I'll do my best to help him since I am the builder and the tuner. BTW, 8 port as well...............float_6969 wrote:It's not just the cross sectional area that matters. It's the port volume as well. The 4 port has greater port volume in both the head and sub-manifold.
To say that trying to get power out of the 8 port head is silly. Trying to get a 4 port head, or even a UK spec CA w/the 4 port head over here to the US is a struggle at best, and you'd better be prepared to part with some of your money as well.
Why would you shell out a couple hundred dollars to get a stock 4 port head over here, and then spend the same money that you could spend on the 8 port to get it polished?
With the work that he's done, it looks to me that he's got a greater cross sectional area and port volume.
Im pretty sure volume is directly proportional to the cross sectional area though..float_6969 wrote:It's not just the cross sectional area that matters. It's the port volume as well. The 4 port has greater port volume in both the head and sub-manifold.
