I started with a 1987 toyota corolla and put a ca18det in it
-cheap got a blown complete swap with new oil/water pumps for $400
-light weight
-small in size
-square design
-rev happy
I sent it off for a rebuild got some tomei 83.5 pistons. Everything else is stock internally.
Mods
-gtr injectors
-butterflys removed
-ka24de tb
-blow through z32 afm
-nistune ecu
-s15 turbo
-custom ss vband exhaust 2.5
-custom manifold
It runs(starts up the 1st time cranking) and drives like a dream, this build was all about response and not massive hp numbers.
Pointers
-plan your build lol
-ground your motor /battery (I ran two grounds off the.battery and it increased the volts)
-research the forums (so much info out there)
-simplify the coolant lines
Enjoy
