pulsar gtr »
https://forums.nicoclub.com/pulsar-gtr-u1034.html
Wed Aug 25, 2004 7:21 am
Well, the drive shaft, remove the round metal hub that is hitting your drive shaft, it comes out by using a hammer and some tapping, then remove the one from your KA engine and install it on the ca transmission, problem solved.
Personally, I haven't used an SR downpipe but lots of people on this forum use it and I don't believe there are any changes to be done.
Z32 maf is good if you are planning to boost the engine higher than stock boost or you are going with big turbo and big injectors, other than that, you don't have to replace it, and if you decide to replace it and you are using your stock ecu, you need to get a piggy back module such as safcII in order to control your air/fuel ratio floow.
Good luck and I hope that info helped.
PULSAR GTR
