ca18det install help please
zm2906
So ive installed my ca18det into my 89 hatch and I'm getting spark to all plugs, getting fuel but no pulse to my injectors so they are not firing. Any ideas of maybe something I wired wrong or plug not plugged in? I'm striking out on ideas of what it could be.
btm88
Car: 1993 S13 Convertible
Is the dropping resisitor plugged in? Or do you even have it at all? Cause this could be your problem.
zm2906
Would I have a dropping resistor for a mt? Where would it be located?
zm2906
ok so I looked into it and didnt see a drop resistor in the car. Where can I buy one and would there have been one for the old ka motor/ where is it mounted in stock form?
Frankenfourty
Car: 1989 240sx CA18DET
The KA does not have one since it has high impedence injectors. You can get one from cars with low impedence injectors. Alot of people use a DSM or honda resistor box. Or you can get a new nissan unit for $60-$70.
dsilvia89
Car: 1989 Nissan Silvia
i am also looking to buy a dropping resistor, did you find one on the net?
zm2906
used a honda one thanks guys. car runs now
