Have someone in the car doing whatever makes the car act stupid and pull the injector plugs one by one until you find the one that doesn't make it worse. Test the injector and the plug there and see if the plug is providing signal and that the injector impedance is correct.
I suspect, however, that your problem is here.
Armendo89 wrote:-The MAF has a blow through set up on the cold pipe
Put it in front of the turbo. Reset the computer and see what happens. That ghetto blow-though AFM s*** is dumb. It was cute when we were using flapper door AFM, but hot wire sensors are a hell of a lot more sensitive.
You have a computer and an SAFC that is tricking it, both that think the signals are based on an AFM that is out in the open air. Too many variables there.
