CA18DET Injector Upgrade? ( Evo 9 inj. fits?)
Spawn_CA18
Car: 1993 EDM Nissan 200SX S13 CA18DET & 1995 EDM Honda Civic Crx Del Sol EG2 B16A2
hi there guys ,
last week i have changed my old blown turbo with brand new GT2860RS .64ar .
BUT with standard injectors , now i see %96 injector duty when pull at 3rd gear . so i can't use car at full throttle and map power fc properly . i don't want to run over %80 duty
so i have to upgrade my injectors .
i have a set of evo 9 DSM top feed low imp injectors , i searched about it but i can't find solid answers about it , some say early evo injectors will fit by drilling fuel rail injector sit to 11mm and some say lately evo injectors are crap for CA18det.
so , is stock EVO 9 injectors will be good , or what should i buy ?
and are GT-R injectors enough for 1 bar @ GT2860RS? i think they are not. i can ind a set of gt-r's but i think its best to ask to you guys
it's a little bit urgent because i cant run my car healthy now..
thank you all waiting or answer :whistle:
mr_ca18det
Car: 1989 240sx w/ ca18det forged and hx35 hairdryer build in the works
Chances are all you need to do is make the injector holes a little bigger . I run dsm 650's from fuel injector clinic there prob really close to evo injectors. And a slight adjustment to the lower intake was all it took. I never had a problem with mine but its kinda pointless too upgrade to like 450's cause they won't help much and its kinda a pain to take off the intake. Not sure what size evo's are but if there like 550's you'll be in good shape. Hope this helped.
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
how much boost are you running to have the injectors at 96% duty cycle? Im just curious..
mr_ca18det
that is a good question i couldn't even run 1 bar on my stock maf and injectors on an s15 turbo. Injectors and maf were maxed out. What else you have done to the fuel system a 255 pump at least and nismo or equivalent fpr I hope .
Spawn_CA18
Here is my part list ,
Motor:
Wiseco 83.0 mm pistons
K1 Forged Rod
ACL Race Main&Rod Bearings
ARP Head Studs
Cometic Head Gasket
New Oem Oil Pump
New Oem Water Pump
Custom exhaust manifold
XS racing turbo elbow
Garrett GT2860RS-5 .64ar
Port polish
HKS 80mm Mushroom Filter
Sandwich plate
9 litre Front Mount Intercooler
Walbro 255lph Fuel Pump
"550cc Evo9 İnjectors"
NGK Iridium 8EIX Spark Plug
bronze Valve guides
Electricity ans
Silicone Radiator hoses
Custom FMIC Pipes
HKS SSQv BOV
76MM Straight Exhaust pipe ( No Mufler )
85'-92'C Fan Switch
XYZ Super Street coilover
Cusco Front Upper Strut
Welded Diff
XTD Stage II Clutch Pack
Z32 300ZX Turbo Brake Calipers & Disks
Schroth 4 point belt
5Zigen FN01R-C 17x8" 35ET Front & Rear
Ichiba 2x 15mm Front Spacer
Ichiba 2x 25mm Rear Spacer
CircuitSports S13 to Z32 Front Braided Brake Lines
Motegi M84 Long Black Wheel Nuts
TCS Rear Upper Strut
electronics:
Apex'i Power FC L-Jetro
Apex'i Boost controller
Apex'i 2 bar Map
FC Datalogit
Greddy Boost & egt & oil press Gauges
Aem uego wideband
Aem Oil Temp Digital
HKS Type-1 turbo timer
Z32 maf
Interior
Sparco R345 95mm Dish
NRG Short Hub
Nismo Black Gear Knob
i read 0.75 bar from Apexi Power FC & Map
after new injectors i'm going to make it 1 bar
mr_ca18det
I would say your in decent shape then. Throw them in should move pretty good at 1 bar.
beans33
Car: 1993 ca18det 240sx
I currently have evo injectors in my ca (560's). Im currently in the process of tuning for good air fuel numbers while cruising. I have heard they flow more then they are claimed to be, which could possibly make tuning a headache. I got mine for free so thats why im using them.
Spawn_CA18
so you say i should give a try with evo9 injectors huh?
a friend of mine told me lately evo injectors may cause some lean mixture problems but i don't now why. so i think its better to try evo injectors and try to map again and keep my eyes on AFR gauge and injector duty..
Spawn_CA18
still hungry for informations :)
mr_ca18det
Throw them in the only way you have any sort of prob is if there not anywhere close to flowing the same. So if you really wanted you could get them checked and cleaned there are a few places that that do this. According to your post you already have them so personally I would run them as is. 99% of the time one dsm or Honda ricer had a prob with a set of them which they prob caused so now someone decided there all junk. That just my opinion but its your car.
ca18hatch24
Car: 92 240sx with ca18det
I am running evo FIC 650cc's on my CA18. Just had to re-use the ca18 o rings. No issues with leaks or anything so far.
Spawn_CA18
Last week i also installed evo 9 injectors on my ca18 . Same as above i used brand new stock injectors o-rings. No leaks or something. No need for re-drill intake manifold.sits like oem part. Brilliant upgrade. İ had decreased my injector duty like %30.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Yeah I run Evo injectors too. No need to modify anything, just like you said. They can be a bit of a tight fit, but if you put a little dish washing soap on the o rings, they go right in.
