Here are the plugs I pulled out while it was running decent (oem ngk v powers)
Here are the ngk 7's (like one mile if that of travel)
I also moved the igniter coil pack ground back to the oem position. No difference.
Car idles at 14.6-14.8 Afr
So obviously everything is working. As soon as I blip the throttle the car goes off the charts lean 17+, I have also noticed my ecu lights have stopped flashing.
If it was a vacuum leak the car would be running rich right?
Fuel pressure is 2.2 bar. It increases with the blip of the throttle as well. I even tried to increase fuel pressure to 3 bar and afr's at idle remained the same.
I am thinking its gotta be my z32 afm is s*** out or I got bad fuel/fuel filter/fuel pump and last but not least my ecu is toasty.
