float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Sun Jan 30, 2011 10:12 pm
Are u running a MAFS? If so, then a boost leak big enoug to cause these symptoms would also keep the car from idling. Even w/a MAPS setup, IDK that it would still idle well.
For these reasons I would say the more likely scenario is a bad exast leak, which you would easily hear, or a problem with the wastegate. If the diaphram in the wastegate fails, there is little to nothing the keep the valve closed in the wastegate and you'll get little to no boost.
if it were my car, I'd pull the wastegate off and dissassemble it to check for problems. i also have an HKS external wastegate, so if you take pics, I'll be able to tell you if there any problems.
