ca18det head
racer_guy89
Car: 1991 300zx tt
I have a 1989 nissan 240sx with a ca18et but i wan the ca18det i have the dual overhead cam head but what i was wondering is if i could put that head on my ca18ET block ?
boost_boy
racer_guy89 wrote:I have a 1989 nissan 240sx with a ca18et but i wan the ca18det i have the dual overhead cam head but what i was wondering is if i could put that head on my ca18ET block ?
Buy the DET motor and save yourself the headaches.
Dee
racer_guy89
Car: 1991 300zx tt
whats the the headace i figured that swaping a head would be easier then a whole motor when ive had the et head off already is it just wireing or wat?
boost_boy
racer_guy89 wrote:whats the the headace i figured that swaping a head would be easier then a whole motor when ive had the et head off already is it just wireing or wat?
Been at this a long time dude, but if you must know I'll tell you. The CA18et is just what it is; a single overhead cam turbo engine. The CA18DET engine is what it is, a dual overhead cam turbo engine. The blocks of each are set up accordingly for their respective nomenclatures (ie et, det). In order to use the DET's head on your ET, you're going to have to tap your block for the DET's timing belt idler pulley. Though the Et's pistons are notched with valve reliefs, they are not a correct for the DET's head. You will need both manifolds, turbocharger, and so forth and so on.
It's okay if you don't take my advice on this my friend as I'm just trying to anwer your question and save you the dramas associated with what you're interested in doing. Good luck...........
Dee
racer_guy89
Car: 1991 300zx tt
thanks youve been relly help full i found a ca18det motor that i can buy so i will do that instead thanks agian
