CA18DET Head: Is it a rocker-arm design?
XFD Raven
Car: S13 SilEighty
I'm looking at upgrading my engine to a CA18DET. If I do get one, I'd like to have some work done on it. As such, I talked to someone who does engine machining and they said that the biggest limitation is the head. Specifically that the head design on the KA/CA/SR is pretty much the same. Talking with someone else, they didn't buy it.
So I've come to you guys. As far as research goes, I haven't found much for an answer. Does the CA18 head use rocker-arms?
c-rad
Car: 1991 Nissan 240SX w/CA18DET
no rocker arms. KA/CA are similar.... SR is totally different.
kapower06
The dohc ka and ca are similar like c-rad said... The sr and SOHC ka are similar. Also a major difference between the ca,ka, and sr is that sr's and ka's use timing chains and the CA uses a belt.
biosehnsucht
direct acting hydraulic lifters just like the VG and RB.. in fact, some of the parts are identical!
