Chinamandrift wrote:Float... what is the highest octane from the pump that your using? which pistons and gasket did you use to get 9.5:1 comp ?
i heard about the H2o injection how does that work ???........theres a company that will make custom carbon fiber intake manifolds ........its suppose to dramatically lower intake temp ........ive seen the ones they make for hondas...big blocks .....they are very high quality......
as for the gaskets ........i would love response more then power .......has anyone else experienced a different compression ratio other then stock ?
I get my gas from BP. It's 92 octane. It's prob actually 91, but it helps me sleep at night thinking I've got that extra 1 octane rating. I got custom pistons made by CP for the 9.5:1 compression. Stock HG, it's holding up just fine. Seen as much as 14 psi on a T28.
H2O injections sprays a fine mist of water into the intake tract. This cools the air going into the motor. Also, since the water is intert in the combustion process it has no ill side effects. It also helps to steam clean the combustion chambers, removing and preventing carbon buildup, which reduces knock. H2O injection by itself does nothing. The extra timing that you are able to run because of the reduced intake temps is where the power is made. A Carbon Fiber intake mani would be cool, but depending on price, I doubt it would be worth it unless they've got flow comparisions vs. stock and the runners all flow evenly.
AFAIK, I'm the only retard that's INCREASED his compression. The off bost response of my motor is very nice. It has decent low end torque for a CA anyway, and the spool up time is considerabally faster than before. Once again, this is all at the sacrifice of severly retarded timing under boost. If I were to do it again, I'd only bump it up to 9:1....
