BACARDI_DWB »
https://forums.nicoclub.com/bacardi-dwb-u44458.html
Wed Mar 17, 2010 1:16 am
What part of the harness looks like it is not reliable? is it the wiring itself or is it the sensors? harness connectors?
I am saying this because there really is not an easy way to replace your harness. If you think your wiring is looking old and you want to replace it, you can replace each individual wire with new wires but that is going to be very time consuming. if it looks like the sensors need replacing then replace the sensors. The CA18 really doensn't have a OEM Replacement for those wires without getting another better looking harness off another CA18, or rebuilding your own.
If you are worried about it, go thru your harness, clean it up, and check for frays, cracks and hard bends and replace the parts that are old and worn.
unless there is a new development that I have missed.
