What ecu are you using? I have an AWD/FWD harness here, but I need to replace the ecu plug because it got crushed during shipping. If and when I decide to repair it and you're still in need, I'll let you know. Why don't you just take your ca16de's ecu and have it remapped? At least you get to have it remapped for what you're going to use and get to use a better AFM to start. Just a suggestion because harnesses are expensive now and personally can't show any mercy on cost because they are getting to be extremely hard for me to find and I thought I had access to most anything for this engine.clark wrote:Hello everyone, Im looking for a harness for a fwd ca18det. I have a ca16de harness will this work if i change the ecm plug? If i can use the 16de harness where can i find a ecm plug? Thank you for any input you can give me
To prevent the headache, you'll at least a bluebird, silvia, or 180sx harness. Trying to use that ecu with another nissan harness can be done, but the headache is not worth it (honestly).clark wrote:well i dont have the ca16 ecm and the the ca18 ecm i have has a big blue plug and the number 78 on it. Is there a harness i can mod to make work for this ecm. from the wiring info i have it looks like the ca16 harness will work but i would need to change the ecm plug.but i may have missed some thing not shure thanks
Clark
