CA18det harmonic balancer
cortina-mk1
Car: GT-R Skyline, MK1 Cortina's
anyone had any problems with these balancers coming loose or apart?
paul_s13
I don't think it has one, well mine didn't.
CA19DET
i don't recall seeing one in the FSM
chezina
Never heard something about harmonic balancers in connection with Ca's.Well maybe there are some top secret CA's out there, u never know...:D
slw240sx
Car: 1990 Ca18det 240sx Hatch
crank pulley maybe?
paul_s13
Yeah I would class the front pulley as a vibration damper, I remember the one on my old 320i BMW it was like a brake disc bolted to the front of the crank!
cortina-mk1
yea there is one fer sureits the bottom pulley on the crankshaft is has 3 belt grooves
when you get your engines balanced you dont include this? or am i misunderstanding you
when you actually pul one apart they are a dampening device.
chezina
Ahh, your talking about the front pulley, normally they don't break, except u use a big hammer to get it of (like i did one time).AFAIK u should balance the whole crank assembly together(front pulley, crank, flywheel and clutch cover), to achieve the optimum.
cortina-mk1
chezina, it didnt break actually it came loose.. we are at a loss to why but we have implemented a better locking and holding arrangment for it this time. BTW no big hammers were used :D
i was just wondering whether anyone else had this problem...
as for balancing you are correct that is how our was done.
we machined one apart to see how much strength was in it etc. trying to figure out why it came loose.
yes it was locktite'd and tightened to correct torque :)
paul_s13
Yes I had a front pulley/vibration damper come loose and it was also torqued and thread locked, it ruined the woodruff key slot in the crank.
cortina-mk1
thats no goodours only wrecked the woodruff key and the balancer
luckily the crank was okdid you notice that pully only fits on halfway on the end of the crank?its a strange thing having that weight right out that far...did you find a solution?
paul_s13
Not really, I had a spare engine so I got the new pulley/crank/flywheel/clutch cover all balanced up again and fitted it all back in.
