boost_boy »
https://forums.nicoclub.com/boost-boy-u2853.html
Fri May 07, 2004 3:37 pm
To all owners of the awesome CA18DET motor,
It has been apparent that many CA18DET owners think they have a motor that can rev to 8000+rpm without dramas. Although the CA18DET can rev better than the SR20DET and the KA24DE, it makes no power in the 8-9k rpm range, unless you have the necessary cams, solid lifters, and valve springs as well as the fuel system to support it. And though the oil pumps are pretty durable, they do fail from neglect as many of you have already experienced.
Spare your engines the grief and stop trying to pull Vtec type revving because they eventually wear out as well. Consistently revving on a used motor will almost always result in rod bearing wear which ultimately results in costly repairs. I hope this shed some light on people that want the CA18 because they've heard it could rev to some insane rpm in stock form. It will let you do it, but you wil wear out your motor in a nasty way.
Dee
