nismoplsr »
https://forums.nicoclub.com/nismoplsr-u10684.html
Tue Nov 25, 2003 4:04 am
i have a ca18det in my kn13 pulsar nx sea few other guys do too
then there is Boost boy with one in his b12 sentra
the ca18de came in the 88-89 nissan pulsar nx sethis is where most of ur parts will come from
transmission, axels, mounts, shifter, linkages, not sure if the sentra is cable or hydraulic clutch, but the pulsar is hydraulic.
the wiring harness from a 87 pulsar nx se(ca16de) can be fitted to the det and then a ca16 ecu can be reprogrammed by JWT to run the det, or you can go with a stand alone system which i recommend.
i am currently running about 250hp at the crank with stock turbo and internals, with an upgraded turbo and fuel system 300 whp is easy on stock internals.
