I don't see a ~3500RPM spool time as that ridiculous... I'm not looking to make 400rwhp here. I think anything more than 300rwhp would start getting a tad crazy in a ~2400-2500lb car. Sure, I'll probably get greedy at some point and want more, but I don't think my goals are unrealistic right now.
You can't always downshift and go into a corner in a lower gear. If there is a really long, sweeping corner, your exit speed at track out can be 20-25mph higher than your entrance speed, and you cannot shift in that whole period. I routinely go into corners at ~40-45mph in 3rd gear with my M3 just because I'd run out of 2nd gear and have a problem. Yet with a peak torque at 3800RPM and a strong pull from 1500RPM it is not so much an issue.
Road racing is a completely different animal than most people realize until they do it. You might not have a 15mph corner, but you still have to use a whole heck of alot of your powerband to get around the course the fastest. If you are not on the brakes, you are on the gas and you can't really shift in a corner or series of corners. So you'll find yourself short shifting a good bit shy of redline alot of places around the track so that you will have a good pull throughout the whole next section. Now does it make sense why I want the broadest powerband possible? I'm not TOO concerned with peak power figures, I'm just throwing those out as a possible amount of "pull" I want around the track to keep up with/embarass faster cars on the straights as well as the corners. I'd much rather take a little more torque and a fat meaty powerband over a peaky curve with good peak numbers.
Ok, so what about spooling fully by 3800RPM with a good transient response? I'd of course try to do everything I could to reduce lag. GReddy O2 extension pipe, good sized downpipe and exhaust with a straight/test pipe instead of a cat. I would also try out a tubular manifold if I could find one reasonably priced like you can for the SR's.
Ok, so let's say it can't spool up at 3500, and it says takes until 4200RPM(which is MORE than reasonable). Can the engine rev to 8000 or beyond reliably with some slightly hotter cams and valve springs? If I can bring it up a hair over 8k then the slow spool time isn't as much of an issue.
This engine seems like it should be able to get the snot rev'd out of it with good valvesprings and enough cam to breathe up that high. How would you handle the software issue of the revlimiter in the stock ECU?
