CA18DEt Experts please help!!
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
r34 gtr wrote:No no no,
Euro 4 port CA18DET used 15deg BTDC base timing, and
JDM 8 port CA18DET used 10deg BTDC base timing.
I always had my JDM CA at the 15deg Euro timing, and I never noticed a problem.
maybe that was it.
float_6969
MrAlex wrote:... i can't feel any air .. just a little from the shaft , but im sure thats normal
No, any air coming from the shaft is ab-normal and is a leak and will make the car run like poo. Timing should be 10°BTDC, not 15.
MrAlex
Car: 180sx
float_6969 wrote:No, any air coming from the shaft is ab-normal and is a leak and will make the car run like poo. Timing should be 10°BTDC, not 15.
Thanks you I will be changing my throttle body out to see if that helps ,also the fms states 15 btdc , and I have a 8 port so it's jdm then.
