-dry test first-engine at normal running temp
-remove all 4 spark plugs and coil packs (noticed the 1st coilpack is pooched)- ground all 4 to the block
-hold throttle fully open
-turn key
-i get 125 psi across all 4
wet test at normal running temp
-ground all 4 again
-hold throttle open again
-turn key again
i get 150 on the first 2 cylinders and when i go to test the 3rd it wont read anything, just bounces off and on 0.
-same thing happened on the 4th
white smoke also came out of i believe the 2nd cyclinder when i did the wet test on cyclinder #3---this is just because i put a little oil in there?
i need to figure this out guys. i am no expert, the extent of my work on this car was swapping out the non turbod engine and in with the ca18det + fmic...body work yadda yadda so im not a total noob...only when it comes to the inside of the engine i am totally stumped.
ps im working by myself
i mean i am grounding all 4 coils and plugs down, while holding open throttle, watching the tester and turning the key...
Thanks in advice to anyone who tries to help me, i appreciate it!!
