I'd be wary of that type of over-bore you speak of. If you went 1000ths over bore and didn't measure the ring gaps, then that could be your problem. If you felt a need to bore, you should have went 20 thousandths over and move to slightly bigger pistons.1.8turboterror wrote:Thanks guys for the feed back. I have a brand new billet ball bearing precision 6262 turbo on her so I doubt its my turbo. Could be gap on piston rings which I really hope it is not. I had the motor bored only 1 one thousandth's over and put stock bore aria pistons in thinking they would expand slightly at high boost because they are forged and I had read to do this with forged pistons on high boost applications.
