CA18DET ECU Tuning and FREE downloads!
Wayside
Car: 11 MT Juke, 93 CA18det 240sx, 06 350z, 90 CA18det 240sx
Hmm this seems really awesome I'm trying to tune my CA for 444CC Injectors and a Z32 MAF, but I have a Blitz Access ECU and I can't seem to find a cable or a program that will work with it...any suggestions??
yourmomsrps13
Car: Drifting ruined my life since 03' 240sx CA18DET
F@ck it! everytime i get my tune close to being where it should be i burn a chip then its starts acting up and running rich again damn these injectors!!!! i shoulda stayed stock
Moedigzz
Car: Ca18det Koop(10.6@128), 16g DSM(12.3@118), pt6785 '90 DA(9.30@156)
^Buy/borrow a emulator and get it street tuned in an hour... Check moates.net for the ostrich2. Worth every penny.
Also, check out ca18det2.escic.com for CA bin files and the latest version of Live Edit.
S13Silvia917
Car: 1990 240SX
*EDIT* found the address file after searching for a long while...here it is the link in case anyone needs it, i loaded up to romeditor along with the stock .bin and works great...
http://ecu2.forumwise.com/ecu2-thread1126.html
Modified by S13Silvia917 at 9:45 AM 1/17/2009
Modified by S13Silvia917 at 3:46 PM 2/7/2009
Nissanclubman
Car: Custom built clubman rodster. CA18DET powered
yourmomsrps13 wrote:i guess not....anyone got the K value address? and i'll just use rom edit
Yep.. can get it to you if you still need it.. PM me or e-mail and I'll send it after I get back home.. Cheers Richard
SN33KZ
Car: 240sx duh
Sorry to be a thread zombie.
But I will pay you 3 dollars paypal if you can give me the right settings for my ca18det. Im using a stock jdm ca18det bin file and need to know what to calibrate to these uprgrades.
. Walbro fuel pump 255 . N60 maf im running at 8 psi currently if it makes a difference . Full 3" exhaust/downpipe. . FMIC . Mishimoto full aluminum radiator (dnt think that would matter ? )
So plz all you tuning guru's helpppp : ]
progman
You don't have to tune for anything you listed except the N60.
If you want to tune for the others stuff (exhuast, FMIC) then you better get to the dyno.
Just download a .bin for N60 MAF and stuck injectors. or do it yourself.
bersh240
from the dead...where can i find live edit now?all the links in here are broken or lead me somewhere that makes no sense to me.i need to tune for:450cc injectorsj30 maf (thats n60?)255 walborosr t25 turbofmic.full exhaust..
and i would like to learn to do it myself. so could someone provide an updated link?
float_6969
http://z31.com/prom/liveedit/my google skilz > your google skilz
bersh240
i tried that site.errors in it.wouldnt work and i have just learned my eprom is to old to use anyway.its a batronix 3.3.. the oldddd style. from 2002..i cant find software.
roast
Car: 1989 Silvia
Too bad most of the links in this thread are dead... A lot of my google searches have brought me back here which leads to a dead end.
If anyone has the info or maps, I'd really like to get a few to look at.
croustibat
Car: 200sx S13 w/ ca18det
This is not free, but it is the best way to do it somewhat cheap, quick and easy :
get a nistune board. It comes will a great software that will do a lot of work by just choosing items from menus, and it allows real time modding. much, much better. I used romeditor at first, but i got tired of losing my time buring eproms.
wideband O² sensor, nistune, netbook, you may add an AGT sensor, and there you go.
basically, the hard job is finding the injector latency value and the right timing. The easiest way is ... to get a stage 1 chip. It already contains a fine tuned ignition map (the oem one is very conservative, you will have a hard time to make it better, so save some time, avoid risking det, get one).
assuming the VE/VQ map is already good, and the injectors are good and clean too -avoid venom crap (it is a guideline, i wont tell exactly because knowledge in this area is value): Here is how i search injector latency: set a fuel map with 14.7 AFR everywhere, with an estimated latency (bigger injector => bigger latency, just apply a rule of 3 here ).Calculate the K value (again, rule of 3) and fine adjust it so your AFR gauge reads 14.7 on idle. Until you have a smooth idle, keep adjusting K and latency.Then, give the engine some revs, and fine tune latency and K value accordingly. As your map is set with 14.7, it should ALWAYS show this value. If it goes lean, latency is too low; rich : latency is too high. Adjust latency and K again, and so on.
Once K and latency are good, you can set a real fuel map. Once again, get one from a stage 1 chip, they are quite nice.
I stopped using premade stage chips directly because i got weird results on my car and on another one, although it was ok with others. The mixture was 2 points too lean, i had to change K and latency a lot, even with standard injectors. I checked everything (fuel pump, FPR, fuel pressure, fuel filter, fuel pickup...) and there was no reason for this but still, it happened.
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
so you're saying to get a Stage 1 Chip to use the Timing and Injector Latency, then use the NIStune board for overall tuning?
I've been searching for how to install chips and what not but haven't really come up with anything.
croustibat
Sorry, i explained poorly. Use a stage 1 chip to get ignition & timing maps. stage 2 & 3 chips are just the same maps with different VE/VQ maps to fit other MAFs, and different K and latency value to fit injectors. Unless you go the e85 route or if you change your cams, fuel and ignition maps will hardly change.
To get injector latency, use the method listed above.
To get the maps from a stage 1 chip ... buy one or ask someone to lend it, read it with an eprom reader, and load the maps in nistune :D
sjbsuperman1425
CA18DET
croustibat wrote:To get the maps from a stage 1 chip ... buy one or ask someone to lend it, read it with an eprom reader, and load the maps in nistune :D
hmm, i wonder if someone who has a Stage 1 chip can and an eprom reader would be so nice as to post up the maps from the chip
roast
Car: 1989 Silvia
I appreciate the response, nistune is very appealing and has already been a valuable resource for me as their base rom back has a lot of stock ca18det roms...
I have a pocket romulator and can reprogram the ecu countless times from my laptop. What is lacks when compared to nistune is the real time aspect.
I'm really interested in a Stage2/3 tuned rom, I have DSM 450cc injectors and z32 Maf. I've set a map to 14.7 and am narrowing down my K value already... it just takes more time without Nistune...
If you have a rom you can share with me, email me [email protected]
roast
Car: 1989 Silvia
Send me an email (see above post), I have a Velislide .bin file you can look at.
I started another thread asking for bins... The bins Rafi posted aren't available anymore, I'm waiting on a domain name and will start hosting later...
