CA18DET ECU Tuning and FREE downloads!
c-rad
Car: 1991 Nissan 240SX w/CA18DET
originalsin wrote:the pocket romulator thats like $180 right?? ok so it sounds liek ill try working with live edit. im on hybridka, searching and trying to figure out how to get live edit to install, i unzip it, and go to install and it says "invalid command-line arguments. Unable to continue." do u recomend picking up a cheap laptop for this? can i use a mac laptop? i have like 3 of those lol.
Must be running Windows. I've run Live Edit successfully on a P166MHz laptop, AMD 850MHz desktop, and now on my 1.33GHz laptop.
originalsin
damn, well any ideas why i cant install on my windows??
c-rad
originalsin wrote:damn, well any ideas why i cant install on my windows??
You're not running something gay like Windows ME, are you?
originalsin
nope, XP, home edition i belive
Edub1
Car: 89 240sx KA-T
Yah, good luck on hybridka. All that goes on there is a bunch of BS. Not one guy on there has successfully tuned a turbo motor from what I gather.
What do you guys think about the MegaSquirt?
originalsin
isent megasquirt full standalone?
pulsar gtr
Car: NISSAN VEHICLES
Ok boys, Have any one of you tried any of the bins yet?Chris, did you have a chance to try the 440cc bin fle?
Thanks,
RafiPULSAR GTR
c-rad
pulsar gtr wrote:Ok boys, Have any one of you tried any of the bins yet?Chris, did you have a chance to try the 440cc bin fle?
Thanks,
RafiPULSAR GTR
Dude, my motor is in my kitchen.
pulsar gtr
LOL, o man, that is too fricking funny, AND I thought you were driving the beast.
Cheers,Rafi
originalsin
ok so i got live edit to work but after im in it for a bit (few mins) or try and liek click a command or sumthing it says run "time error '6' (and i think i got '11" before) overflow" and closes, wat gives?
tineira
The link to this thread in the FAQ is broken:zer...59814 instead ofhttp://forums.nicoclub.com/zerothread?id=143518
nuts510
Car: sr20det 95 240sx, rb20det 93 240sx convertible, 78 280z turbo, 71 ca18det datsun 510, 72 scout,88 CR
that would be very interesting to me especially if we can use it on a rear will drive car I would be more than interested in being the guinea pig I even have three ECU in my possession if you are reprogramming the stock units get back with me Jay
float_6969
tineira wrote:The link to this thread in the FAQ is broken:zer...59814 instead ofhttp://forums.nicoclub.com/zerothread?id=143518
I'll fix it right now...
tattman77
Car: 92 240sx coupe w/ca18det swap top mount 20G and s13 silvia front end
originalsin wrote:isent megasquirt full standalone?
I was looking at megasquirt for my 1st gen turbo neon. For the neon it was your choice if you wanted full stand alone or just fuel or just spark control. I have not looked for the nissan setup yet. I just got my 240sx project yesterday. I am a noob when it comes to factory turbo setups such as the ca and rb motors. lol
burnout 180
Car: 1990 s13 180sx ca18det
So what are these bin files for and how do you use them?
What do you need to use them?
Do you just get your ecu chipped and then all you have to do is connect your ecu to the computer and start tuning away because if so that would be great because i thought that everytime I do an upgrade to my engine e.g(add a Z32 maf and larger injectors) then I would have to take my car back to the shop to get the ecu retuned.
If this means I can tune my ecu by myself please tell me more and what all i would need to buy to do this because this would save me alot of money.
I know hardly anything about tuning.
btustison
Thanks,
RafiPULSAR GTR
Hey I have a Z32 MAF on the way, and I already installed a socket in my ECU. I will give you some feedback and a dyno sheet with AFR when I get a chance.
pulsar gtr
awesome,
What size of injectors are you gonna be running?
Thanks,
RafiPULSAR GTR
Akihisa
Car: 300zx, Italjet Formula 50Lc, Italjet Dragster 180
Can I use 27c512 chips instead of 27c256 chips? If I can, is there any advantage or disadvantage? The reason I ask is I have alot of the 27c512's and not too many 27c256's.
c-rad
Akihisa wrote:Can I use 27c512 chips instead of 27c256 chips? If I can, is there any advantage or disadvantage? The reason I ask is I have alot of the 27c512's and not too many 27c256's.
Look on ebay man.... you ideally want a 27C128 so you only need to copy the file once. You can usually find a lot of 50 used 27C128's for like $10. You just need to erase them. Out of 50, you will probably get at least 30-35 that are still good.
datsunboy
Car: Datsuns
yes....you can use 512's....I just finished making a daughterboard so that you can use a 512 chip with 4 different settings on it, and switch between them on the go.
you dont need a daughter board tho....if you only want one setup, you just have to copy it on the chip 4 times and you'll be fine.
datsunboy
Car: Datsuns
heres a pic
LMQT
Car: 200SX RS13
pulsar gtr wrote:please give some feedback.
You have modified the K number for the injectors but not for the Z32 MAF And you omit to consider the latency for the different injectors. Theoricaly, latency is increasing with the size.
datsunboy wrote:I just finished making a daughterboard so that you can use a 512 chip with 4 different settings on it, and switch between them on the go.
Really interresting Have you got schematics or something like that ?
pulsar gtr
Hi LMQT,
I calculated the K number according to the new injector size which isn't related to the Z32MAF, how ever I illiminated the first 12 values for the Z32MAF VQMap.
Is there an equation to calcuate the Latency? Also, I am using "ROM Editor" and they don't have a latency, they refer to it as "Void blast-Off time".
I guess some one has to give some of these programs a try in real life sensarios in order to get some feed back on what exactly they experience.
Thank you for your input.
RafiPULSAR GTR
LMQT
Car: 200SX RS13
Yes Injector Latency = Void blast-Off time.With stock injectors, it is about &h37.With 444cc (RB26DETT), &h3A to 40 is good.And with 550cc, something like &h4A to 4F should be good.In fact, it depend on the injector brand : a value for one could not be good for another one. And the difference is more important with bigger injectors.
You have to change the K value according to the MAF in order to indicate at your ECU a sort of correspondance between the two MAF because the high and low values are differents in MAF tables.You can find a start of explanation on this page.
datsunboy
Car: Datsuns
yes I do have schematics, tho I would like to do a bit more testing first
LMQT
Car: 200SX RS13
OK, we're weating
1SlowCA18DET
im first to try and maps do not work, it idles but as soon as i try and give it some gas it'll bog as its getting to much gas? Someone help i have no car right now dunno if the problem is that im using live edit with a romulator instead of rom editor?
Modified by 1SlowCA18DET at 9:38 AM 12/12/2005
pulsar gtr
Hum,
What setup do you have 1SlowCA18DET? what injectors and maf are you using? would you be able to burn one of the programs on a eprom and give it a try? instead of using live edit.
Thanks for your input, I will take a look at the program tonight to see if I can figure it out. But I would like some one to give it a try using an eprom.
Thanks,
RafiPULSAR GTR
1SlowCA18DET
nope i have no way of burning an eprom, my setup is 55cc rx7 injectors, z32 maf and sr t25 turbo.
pulsar gtr
HI 1slowCa18DET,
email me your address and I well burn you one, here is my email address. [email protected]
RafiPULSAR GTR
