Ok guys, I'm new here and have a question(or 3). I recently purchased a 1990 240sx HB w/ca18det. When i bought it it needed an ecu so I bought one from a guy in Canada,it also came with the stock MAF, plugged in the ecu and the engine started up
Now it will not idle past 2000 rpm
with a little research and looking in the engine bay I found that it has a different MAF (Z32),the guy i bought it from says that the maf is good but i heard that I need to reflash this new Ecu for the z32 MAF is this correct? If so, where can I get this done? Or can I just install the stock MAF for now? And if so, what wires go where? the person that did the swap used cat5 cable to bring the MAF wires from the passenger side to the MAF on the drivers side. I bought new cat5 cause he had the wires running over the radiator and cat5 gets brittle from heating and cooling so I planned on replacing and re-routing it anyway.
