CA18det Crank/FLywheel Bolt Part#'s ??
slideways
Car: drifting/touge/auto cross
yeah so i broke the bolt inside the crank and extracted it myself, came out pretty good but i now need another bolt, i i've been looking arround and searching for the part number and wheather its compatible from the ca18et or ca18det FF but again i have found no info, can someone help me out by tellin me where i can get one from??
any help is much help
brandon
float_6969
I used the ones from a 1987 Nissan Pulsar SE DOHC.
float_6969
PN = 12315-55M00
slideways
Hey, thanks you float_6969, i raelly do appreciate that. i was about to just say forget it and run 7 bolt but i figured that would throw it all off balance so yeah thank you man. " i bow to thee"
brandon
float_6969
Yea, I'm glad you didn't. That isn't something you want to leave a bolt out of. But just to warn you, it took me almost 2 months to get that set of bolts in. But that was also at the time that Nissan of North America was having problems getting parts from Japan.
redamnavit
Mine took about 5 weeks, and I went with the pulsar bolts too. float, did yours look a wee bit shorter than the originals? Mine seem to be.
nocwage
By wee do you mean like 1mm?The bolts will stretch when you torque them down.So one that's been torqued will be a TEENY bit longer than a "fresh" one.
float_6969
Yea, mine were a little shorter than the ones that I pulled out. Only, it was pretty noticible. I had looked at the wrong torque specs when I tightened them down when I first put the motor in and they were VISIBLY stretched. It was pretty crazy to see metal do that. I'm just lucky they didn't break and I didn't loose any limbs from the flywheel coming off or anything...
