float_6969 wrote:Bad ignitor or bad ecu. The circut is being held closed on that coil and it's overheating and melting. I'd replaced the ignitor (ignition amplifier in Nissan terms) first. It's much more likely. It's also possible that you've got a wiring problem that's causing that particular coil to ground out and overheat.
Keep in mind how a coil works. They're not designed to have current pass through them for long periods of time. If that happens, they overheat and melt.
I am leaning toward it being the ignitor as well, now that I have done some research. I asked one of my 240 buddies here locally, who also happens to be an elec engineer, and that was the first thing he suggested. Basically, the way I understand it, the ignitor has four parallel resistor circuits, one for each coil pack, and it could be that the circuit for the #3 cylinder is screwed up.
On that note, anyone have an ignitor they will sell me?
I will check on the other suggestions as well.
