CA18det clutch disc fitment in a ka24de engine
progman
Before I just assume this will work I thought someone might kind enough to share their options on this. I bought a new clutch for a ka24de engine but I want to use it on my CA which is being built.
My KA engine's clutch is terrible; it's slipping. My CA clutch disc is still in good shape with most of the wear material left. So I think the cheapest way to do this would be to throw the CA disc in the KA and use the new clutch for the CA.
Please let me know,
Thank you
-Ben
progman
No ones knows if the ca clutch disc will work in the KA??? I assume that it does. I'm going to try it...
240 Trainee
It should, I'm assuming since you can use a KA clutch in a CA
progman
Yeah, just wanted to make sure before i wasted 6 hours in the cold changing it. I changed it Friday and it worked fine. So now I have my centerforce DF for my CA build YAY!
time to finally install my transmission to my block!!
progman
old clutch.
