ca18det CAS question
coolking4
Car: '91 s13
Hi, I have 2 CAS's 1 with bad bearings and 1 with a broken pin, is it possible to change the pin from the one CAS to the other, if so please explain how. Thx.
float_6969
AFAIK, you can't take them apart. Maybe if you drilled the heads off of the bolts.
bentvalves
Car: 89 Silvia K's
no they are removable, its called a slotted tamper proof one way screw.
I dont think they wanted it being serviced!
