This one is pretty easy to explain. ECU uses different timing maps for neutral idle and in-gear driving and the switch that triggers the transition is near the shifter "gate". In my car I can get a similar effect by trying to gently pull the shift lever into gear with the clutch pedal out.11/ found now idle speed drops if you push gear selector forward or back) when aleady in gear (manual) when hot
Are you sure you're calling this by the right name? Because I'm 99% sure CA's don't have a cold start injector. ECU just increases pulswidths when cold.4/ new cold start injector
Any idea how/if idle is affected if one doesn't have those transmission sensors plugged in?Buddyworm wrote: This one is pretty easy to explain. ECU uses different timing maps for neutral idle and in-gear driving and the switch that triggers the transition is near the shifter "gate". In my car I can get a similar effect by trying to gently pull the shift lever into gear with the clutch pedal out.
Are you sure you're calling this by the right name? Because I'm 99% sure CA's don't have a cold start injector. ECU just increases pulswidths when cold.[/quote]4/ new cold start injector
I'm assuming that by throttle boy, you meant throttlebody, but were actually referring to the intake manifold.04xr6t wrote: I call it a cold start injector (its the large solenoid on the highest point of the throttle boy) sitting by its self (i believe its a 2 pin connector)
Only when cold. If it's stuck midway, it will cause all sorts chaos. If it's stuck closed, you car will not fast idle when closed and not be all that happy when warmed-up. The solenoid at the highest point of the intake manifold controls the idle-up feature for when the a/c is engaged.04xr6t wrote:Cool, ok im getting closer now
terminology is always hard between different people
So the air bypass is the only item that actually controls the idle speed (hot and cold?)
Good question! I'm not sure what the default mode of the switch is (ie: does the ECU read normal in-gear timing map when unplugged or the idle timing map when unplugged) but I have a feeling it defaults to "in gear" if there's no signal/the connector is detached (I don't have the time to research right now). If that's the case then driveability should be fine, but I would expect the engine to idle a tad rough and too low with unstable AFRs.cbh148 wrote:Any idea how/if idle is affected if one doesn't have those transmission sensors plugged in?Buddyworm wrote: This one is pretty easy to explain. ECU uses different timing maps for neutral idle and in-gear driving and the switch that triggers the transition is near the shifter "gate". In my car I can get a similar effect by trying to gently pull the shift lever into gear with the clutch pedal out.
Page EF & EC 12 of the FSM outlines the functions of all the air regulator solenoids.04xr6t wrote:Cool, ok im getting closer now
