ca18det cams question.
ca18detseek
Car: 180sx ca18det
hi , i have some question about setting my cam.does any one try to put the ex cam on intake and retar 2 deg and tomei procam 260 8.5mm and advance 5 deg. thx
ard
Car: 1989 200sx ca18det
i did not get your question clear, but there are several ca's that are running with exh cam on intake side. you just need vernier pulley (adjustable cam sprocket) to do the timing correctly.
read more at uk's sxoc -> http://www.sxoc.com/vbb/showthread.php?t=281511
float_6969
Your question is a bit confusing, but as ard said, if you want to run an exh cam on the intake, just move it one tooth clockwise.
