Since you have never operated the ecu to display codes before I sugjest trying again with the sequence float explained. Or for a better description refer to the FSM as mentioned earlier
float_6969 wrote:... Please refer to EF&EC 64 and 65 in the FSM.
The ecu may be bad, though, I think you should do you best to ensure your doing it correctly.
