CA19DET »
https://forums.nicoclub.com/ca19det-u7344.html
Wed Mar 01, 2006 7:24 am
NISSAN EXA. Be too heavy the car weight vis-a-vis 1600cc.
It makes 1600 cc -> 2000 cc.The short engine of CA20EThe cylinder head single cam of CA20EThe left CA16DE right CA20EThe piston of neo RB25DET is diverted to the block of CA20.From 84.5mm of CA20 in 86mm of RB25.It unites also the high cam.Timing belt of special order.The engine is loaded. Once the rammer foot.Completion of 2,046cc exa. Torque thickly is. 2003/11/1Main point of NA �ƒ…ーン, it makes the big throttle.The left = CA16DE normal right RB20DET normal.Those of RB20 are installed.p
looks like a ca20 block/ca18 crank rods with a ca16de head, NEO RB25DET factory forged pistons, and that combo, with the increased bore from 84.6 to 86mm and i believe the RB25DET NEO si a 9:1 pistons, probably makes it about 10:1 NA screamer...
