So I searched for the KA bolt specs; 10x1.5 (coarse thread) and based on the lengths of bolts Nissan used for the KA bellhousing (25mm, 45mm, 60mm, 65mm, 70mm) and looking at EPP's picture (yes it did help, thank you) I feel confident in thinking the bolts in his kit are;
Thanks man, sounds good. You will be doing the CA community a favor as I've found it impossible to get a straight answer for all the bolts.blownhemi wrote:I'm pulling the engine this or next weekend, I'll be able to tell you, what I have in there. Hopefully what I have are still the stock ones... previous owner was kind of a cheap tinkerer.
Code: Select all
head(mm) Length Thread Length
14 65 20
14 65 20
14 85 25
14 85 25 (this was for the starter mounting)
16 80 80
14 80 23
