clintr33 »
https://forums.nicoclub.com/clintr33-u94094.html
Sun Apr 06, 2008 9:35 pm
Hey people, Only just found this forum while searching for CA help. I just bought a 180SX with a CA18DET.
I have **** all power under 4k, when the turbo kicks im go's hard. But down low just have no power to even get up my driveway. I Checked all the eaths, vacume leaks, has new splitfire coil packs, iridium plugs. O'2 sensor was stuffed, so got a new one. Wired it in. Checked the ecu for fault codes. get a knock sensor and TPS code. hmm, so checked if the O'2 sensor is working on the computer, said it's working fine. I thought maybe the cat was blocked, so got under the car. and it's a fully welded in car, so cut it off and punched it out. ;p not sure where to go next.
