Ca18det aftermarket manifold gasket
Ghost_silvia
Car: 1991 nissan silvia s13
Does anybody have an extra aftermarket exhaust manifold gasket laying around? I bought a SS autochrome one and the mechanic I let put it on probably didn't do the torque sequence cause it blew in the back. Anyway if not I'll probably go back to stock minus the rust. This is the last time I let a noob work on my car.
roplusbee
Car: 2007 350Z NISMO
Mine did the same thing. The fellas laghed and told me to get the stock Nissan gasket.
drifting circles
Car: 240sx
I used the stock nissan gaskets but on my exhaust mani. I blew 3 different ones in one month. Ill never use those dam things again!!!
meminto
Car: S13 Silvia CA18DECT
You will find that the face of the manifold is not true if there is repeat blow outs
Take the manifold to someone and have the face machined dead flat...
I am about to use cometic mls exhaust gaskets on my current build to see how they go...
drifting circles
Car: 240sx
ended up buying those (cometic)
float_6969
Those SSAC mani gasket's are crap. Use the stockers. If they blow out the face of the mani isn't straight.
roplusbee
Sorry, I assumed that the manifold amd mounting surface on the block were checked for straightness prior to my post, which equals fail on my part.
