mexican wrote:beans33 wrote:Still sounds like a maf related problems. Have you checked the ecu for trouble codes ?
the code comes up 55 so no problems by the computers . but do you know if the battery was disconected how long after the battery was conected how long will it take the ecu to re read any codes and does the engine half to be running for the ecu to pick up codes .
going back to square one my ca18det idles smooth no hesitation no stumbeling just smooth whene i rev it up it 0nly goes back and forth from 1800 to2100 rpm at a even beat aprox 75 peats ber min this is what i have tried so far
tested intercooler and piping (good)
replaced all fuel lines with 5/16" lines
tried 3 different stock mafs
tried 2 different stock ecu
tried different thottle sensor
checked the compretion on the fuel system (good)
checked for vacume leeks (good)
timing (good)
fuel tank was cleaned and 94 oct fuel added
i think i have narowed it down to injectors i checked the spark plugs and they were all black (to rich) they are stock 370cc injectors .
i hooked up my timing light to a injector and discovered that the injectors have been cutting out witch is creating my pulsing rev.
DOES ANY ONE KNOW WHAT WOULD CAUSE THE INJECTORS TO CUT OUT COULD IT BE THE DROPPING RESISTOR? I ALREADY TRIED A PROVEN WORKING ECU WITH NO CHANGES IN RESULTS.
