Can be done on a fresh, but standard bottom end. Your major concern is your turbo selection (Gt30-Gt35r or T3/T04E, etc), injector selection (650cc or better), and a decently tuned chip or engine management system. That's it........d.p.n.s wrote:g,day alli know you guys have prbly done this .
but im wanting to get 300 hp at the wheels but i want itto be reliableis this possable?and what would i need?and can it be done on standard but fresh bottom end?
cheersdan
thanks matethe only reason im useing a surge tankis the mtor is in a 1969 mk1 escort van and the fuel sloshes around under corneringand accleration lolfloat_6969 wrote:Surge tank is over kill. An in-tank walbro 255lph is plenty.
444's would do it, but 550's would be safe and give you some headroom.
Yea, S15 SR T28 will get you there.
You can put the exhaust cam on the intake and retard (IIRC) the cam 1 tooth and gain a little power, but not a whole lot.
ill be using a link storm ecu its a full wire in jobbyand it does away with the mafs as the z32 one is aroundthe $400 mark here in n.z and the escu is about $1200so ill just put the $400 to it lolfloat_6969 wrote:Gotcha. Well if you get the Horsham chip, make sure you get 444's and a Z32 MAFS as that's what the tune is for.
a mate of mine wreked his race car and parted it outDanski wrote:Where are you getting a storm for 1200 from?
yeah i wouldnt go to nzefi mateDanski wrote:Friggin sweet, thats a damb sight better than the 3500$ that NZEFI quoted me for a complete install of one
retarding by 1 tooth is not enough to get best result.float_6969 wrote: [...] You can put the exhaust cam on the intake and retard (IIRC) the cam 1 tooth and gain a little power, but not a whole lot.
