float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Wed Nov 03, 2010 11:34 pm
Alright, first off, WELCOME! I was a MAMC at the convention this year, it's a great track! Now to answer your questions.
Where did the CA18DE come from? Have you had it apart at all?
IIRC, the JDM CA18DE's only differed from the CA18DET in the pistons. I COULD be wrong in that. Themadscientist would be the best person to consult as he's actually owned a CA18DE. If I'm correct, then yes, the motor can boost.
You'll need the turbo manifold, a turbo (I would recommend an SR20 T25), O2 pipe, down pipe, Coolant lines, oil feed and drain lines, CA18DET oil pan (or have a fitting welded to your pan), intercooler, and PROBABLY injectors, MAFS, and ECU from a CA18DET.
For your power levels, stock cams are alright, or Tomei PON (not the PRO) cams are good. No loss in bottom end, and it wakes the top end up nicely.
I doubt it. Maybe. Better have a wideband and watch it like a hawk at first.
A wide band tells you what your AFR (Air to Fuel Ratio) is. A Standalone is used to tune an engine. If you have a competent tuner in your area that can chip tune, don't bother with a standalone. Get a wideband and have the engine dyno tuned using the stock system.
Only person I know with experience building a NA CA18 is TMS (Themadscientis). He said it was fun, but not all that fast and you had to rev the piss out of it to get it to do anything. Being in the mid west though, I would say that if you were to build the car with the idea of running E85 on it, you could get some intake, head, and exhaust work done, cams, and some crazy high compression (I'm thinking somewhere around 14-16:1) it might make for a decent motor.
Engine mounts should be fine as long as they're not torn or broken.
I'd run the same tire front and back. The CA balances the weight of the car out alot and, unless you're runing A LOT of HP, I think the extra tire in the rear will make the car push.
If you haven't already, check out the FAQ. Lots of good info in there.
