1) About the coolant/oil lines for the turbo. The old DET block had holes tapped in it, that attached to lines that went to the turbo. The DE block has no such holes (DAMN IT!) so I need to know how to do this?
Can I tap them myself, or is this something only a machine shop should do? It looks like it has the coolant return hole already there in the block, but it has a bolt in it to plug it. The oil feed line, however, is just a round spot on the block (looks like it wants to have a hole
I assume I can use my old coolant feed line that went behind the head and my old oil pan... so its only really the one oil feed line that I need. Suggestions?
2)Is there anything else I should consider doing/ or have to add when turboing this CA18DE? I have a new headgasket/ head bolts/ complete gasket set from Nissan... anything else you would suggest doing?
Thanks (pictures coming soon:D)
Sean
