Post by yellowcell » https://forums.nicoclub.com/yellowcell-u25958.html Tue May 02, 2006 4:22 am
Post by boost_boy » https://forums.nicoclub.com/boost-boy-u2853.html Tue May 02, 2006 4:43 am
Go buy a CA18DET engine and save yourself the headache. Or do a search because this topic has been covered before.yellowcell wrote:i can get a CA fairly cheap. If i get a turbo manifold and a turbo and slap it on will this work fine? wont the injectors crap out on me? and what about the stock configurations on the ECU? what should i do? and if i added a turbo to it like a t28 will this run as good as an sr? should the block and head hold up good? im thinking about a new head gasket and takeing apart the water pump and oil pan to re-seal them. Please help.
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
