240jedi »
https://forums.nicoclub.com/240jedi-u133923.html
Sun Aug 02, 2009 8:18 am
It appears my ca18det has a bad bearing. I'm thinking if it is a good idea to get a ca18de block + intake mani drop it in and use the ca18det exhaust manifold, turbo, ecu, harness and 02sensor. What else might be needed? Can i use the et harness, ecu, turbo etc on the de block and intake easily?I have modest power goals and just want to get going for now, without shelling out too much. I know its a higher compression, so how long will i have till it blows too, and how much of a difference does the piston oil squirters make? The other option is ofcourse to get a ca18det engine, if the na+t is too much trouble.A rebuild is going to cost a whole lot more even for a stock rebuild and i don't think i can justify it right now, though it is the most reliable.
