float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Tue Jul 14, 2009 3:56 pm
As the others have stated, it has probably damaged some of the valves when the belt broke as it's an interference motor. You could try to put a new timing belt back on it, but I seriously doubt that it will run well, and you risk breaking the heads off of the valves and ruining the pistons as well.
As for the oil leak, it could be any number of things. Can you figure out the general area where it's coming from?
