pulsar gtr »
https://forums.nicoclub.com/pulsar-gtr-u1034.html
Mon Mar 10, 2003 12:28 pm
It is either your coil or your power transistor modules, I don't know about you guys, but I've owned 3 pulsars and I usually replace one module per car per year;;go figure.
As themadscientist said , check if you are getting a spark on the spark that you suspect is not firing, if it is not firing, swap the coil with a working one, if it is still miss firing, it is definitely your power transistor module. It is located on the top right hand side of the engine, above the transmission, it is square in size and it has an aluminum heat sink type of shape.It is bolted on with 4 8mm long screws
Good luck,
PULAR GTR
