CA18DE power?
lessthanjakejohn
How much power can I get out of a CA18DE.Saying that I already Had obtained one in good condition and II had a 240sx in goodcondition. My budget is 15,000.
Mad scientist, how much are you expecting out of your CA18DE and are you spending a lot or are they mostly junkyard parts?
themadscientist
I pulled 150hp out of my old DE with an HKS header, HKS 60mm muffler, Blitz air filter and Apexi SAFC. A maximum effort CA18DE non-turbo could make it to the 200s It is low on torque though with such a small displacement. It has a narrow powerband in the upper RPM reaches. If I was going to go full tilt NA I would seriously look at the KA24.
lessthanjakejohn
Quote »If I was going to go full tilt NA I would seriously look at the KA24.[/quote]
Too bad it isn't square...
themadscientist
neither is an L28 but they pull 12s in mainland all day long.
lessthanjakejohn
Whats an L28 6cyl Z engine?
themadscientist
yup. I have the latest issue of CARBOY on my desk, hot nihon-honey on the cover in front of the Endless R34 track car. Flip to page138 to the standings from a drag meeting up in mainland(god I would kill for a real dragstip on Okinawa!!!).let's look at some standings
I will just point out the winners first in each engine class
RB26 in an R33 GT-R 9.201RB25 in an R32 Skyline 10.257RB20 in an R32 Skyline 11.699SR20 in a 180SX 9.922CA18 in a Silvia 10.763FJ20 in an R30 Skyline 10.972VG30 in a Z32 300ZX 10.429L turbo in a 240Z 10.185
Now two NAs that remind us that turbo is not the only avenue to power and speed
VG30 NA in a Z32 11.374L NA in a 240Z 11.404
These #s should fuel some spirited debates across the engine boards :evilhaha
hotshot240sx
Car: my 240sx
ca18 is a good motor...descent power...does this motor drop into an s13...its obviously cheaper than an sr20...you dont get as much hp or torque and the potential is a bit lower...but is it a compatible swap????
lessthanjakejohn
it did come in a JDM silvia J in the same years as the DET. If you weren't doing any major mods too it I wouldn't think it would be worth it
S2000_69
CA18DE or DET ? if is N/A, and that old motor, i say ..... about the same as a civic EX (only)
I am Technoman
Car: ???
S200 do you have a S15?
themadscientist
a tight motor with good compression will net you between 140-150hp with basic boltons. Bump up the compression, throw some cams in and have the head worked and 200hp is within reach. It's a revver though with a narrow powerband.
