CA18DE parts on a CA18DET??
DJ_SpaRky
From what I understand alot of the parts from the N/A FWD CA will fit on the Turbo RWD CA, if this is correct, what parts are they, beacause they are all over the 'yards, & the Tubro ones I'd have to buy from Nismo or a local Nissan dealer.
Thanks in advance for the help. :D
CA19DET
search search search search some mroe, og back and check older posts... come on...
DJ_SpaRky
I did, I did, and I found that the Oil filter fits but that's it, I'm trying to see about the expensive parts.
NeedCAforS13
Car: CA swapped S13 coupe
pretty much everything fits...what do you need? the pistons are higher compression on the pulsar, but technically they fit! both of the manifold(s) gaskets fit, front main seal, rear main seal, etc... but do search harder. I know its out there cause i asked the same questions ;)
Sean
DJ_SpaRky
OK, thanks, that's all I wanted to know, is if I was told right.
