float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Thu Dec 10, 2009 4:07 am
We don't have that van, or that motor for that matter, here in the US, so most of us won't have any experience with it. There are some ppl from New Zealand on here though, so maybe they can chime in.
Also, the CA18DE doesn't really have a whole lot of low end power. Below 3K, this motor is pretty worthless. I'm not saying it won't work, you just need to be aware that you're gonna have to keep it wrapped up all the time to keep it making power.
What about a KA24DE? Do they have that motor there? It's got a lot more torque and I would think that it would move that van around a lot better than a CA18DE would.
Regardless, anything can be done w/enough money. If I had to guess, you'd have to build custom motor mounts, custom transmission adapter, completely redo the fuel system as yours is probably a return-less system, and the fuel pump and lines are probably all way too small. The wiring will have to be figured out from scratch since none of them are going to plug into anything on your chassis. The FSM (Factory Service Manual) is available for download in the stickies. Either that or you'd have to buy a standalone. IDK what clearance is like, but you'll probably have to fabricate a custom intake, and exhaust as well. Another thing to consider is the oil pan. I don't know anything about that chassis, but it's possible you'll have to modify the oil pan so that it will clear the sub-frame.
You can turbocharge any internal combustion engine. Even if the porting is bad. You'd only be running 5-7psi. That would yield you an easy 30-60whp, which should easily meet your goals. I'd be willing to bet money that it'd be way less work to build a custom turbo setup than it would be to get a CA18DE into that chassis.
