Do you have the intake manifold off? If not, there's a bracket running from the manifold down to the block. Shouldn't be anything else besides timing belt and head bolts.
You really won't know if it's good until you get it to a shop and have a pressure test run on it. Hopefully it isn't in the junkyard cause it bent valve
It's unlikely a junkyard head will be ready to slap on another motor without a rebuild.
