nismo.rac3r wrote:16603G - 16636-V5000 Insulator - Injector Per Veh 04 This is the upper o-ring. Fuel rail to injector.
16603F - 16635-V5000 Insulator - Injector Per Veh 04 This is the middle one, which I guess you already have.
This is for the USDM CA18DE, which has a totally different fuel rail from the JDM one. The injector seems to be permanently attached to a small piece of rubber hose. The o-ring might be the same, but not too sure right now... Hope this helps!!!
Thanks for the input. Yeah, I really need an upper o-ring compatible with the CA18DET injector+fuel rail. If anyone else has any thing to add I'd love to hear from ya. I'm thinking that most peices should be the same. I have DSM 450cc blacktops that are going into my DET rail, maybe new OEM DSM o-rings would work? Anyone on here using DSM injectors and have re-used their injector-to-rail o-rings?
thanks guys,
-M
