ca18de fuel injectors?
project350sx
Car: Automotive Tuning
hey guys, just one quick question. I heard somewhere, can't remember where, that CA18DE fuel injectors swap onto the KA24E fuel rail. Is this true? Are they larger flow than stock KA24E injectors? If they aren't and they don't fit, then are there any nissan injectors that swap onto the KA24E fuel rail that are higher flowing? If there isnt any, what would you recommend for an aftermarket high-flowing fuel injector for a mild boosted engine (7-9psi appx.)
I am Technoman
Car: ???
you will need top feed injectors. I would not use CA18DE injectors. I know I know the CA has top feed but i dont think they can flow like you want them to.
huguetpj
Car: 93 KAT Coupe
The CA18DET injectors are 370cc. I believe I read somewhere that the RB20DET injectors are also top feed and 370cc.
That's about it.
Nathan
So are RB26 injectors if I remember right, 440cc's too.
mulletmrt
Car: Videography and Film
370cc CA18DET injectors should do fine on that amount of boost, thats the same platform I'm going to use on my KA24E-T project.
Tx-Sx-FS
Car: S13 KA-T
but arent the 370s out of the ca low impedence and the ka24e are high impedence..u have to buy resistors for each injector which is like 50 per
huguetpj
Car: 93 KAT Coupe
Not 50... try more like $2 a piece if not less. Just need a 10W, 12Ohm resistor if I'm not mistaken. Try jameco.com or digikey.com
Tx-Sx-FS
Car: S13 KA-T
oh..thats cool..but they will fit with those resistors?
huguetpj
Car: 93 KAT Coupe
Tx-Sx-FS wrote:oh..thats cool..but they will fit with those resistors?
The resistors go anywhere on the line, in series with the injectors. So you could put them next to the injectors or next to the ECU... or anywhere in between.
Tx-Sx-FS
Car: S13 KA-T
what do they look like? i need one per injector right? i was thinking it sat in the injector spot and that there was a gap that the resistors settled...but i guess not..its like a fuse or something to handle with the impedence..how much do the injectors usually run?
huguetpj
Car: 93 KAT Coupe
It is kinda like a fuse. No idea on how much the ca injectors are going for these days... $150 maybe?
Digikey resistors
These could work. Although I'm not still sure you need such a high wattage. Maybe somebody else who has done it can chime in. But anyway, those are $5 so it ain't that bad.
And you need one per injector
Tx-Sx-FS
Car: S13 KA-T
i need to know that..and if i were to buy the 93-98 supra plug wires for my turbo car..would i use the supra turbo or non turbo wires? its the autolites that can take the heat range...any idea
huguetpj
Car: 93 KAT Coupe
Tx-Sx-FS wrote:i need to know that..and if i were to buy the 93-98 supra plug wires for my turbo car..would i use the supra turbo or non turbo wires? its the autolites that can take the heat range...any idea
Why the heck would you buy supra wires for your 240? Get some nice NGKs
Tx-Sx-FS
Car: S13 KA-T
for turbo apps? if i goto NOPI and get the ones on there..there like 25 for the wires..but will they be able to handle heat range..also the plugs are like 15 total...but im wondering if there is a particular number or something for the wires that isnt on the site..heres the site http://www.nopionline.com/nopi...01989 just click on the NGK one...
Tx-Sx-FS
Car: S13 KA-T
Tx-Sx-FS
Car: S13 KA-T
that last one for the plugs says resistors next to it..so is it not the actual spark plug?? and i need to look somewhere else?
huguetpj
Car: 93 KAT Coupe
You don't need "special" wires for a turbo app. Some nice wires like the NGK should work fine.
Don't know about those plugs (yes they are plugs), some NGK (stock) but in a colder number would work fine. Search NGK spark plugs in this forum.
Tx-Sx-FS
Car: S13 KA-T
ok..ive seen around that you can get different heat range ones..but if i were to goto autozone or something..would they have them or do i need to goto a online site to order?
huguetpj
Car: 93 KAT Coupe
Here you go
Try the NGK BKR6E-11
I myself went with the K22 (?) Denso Iridiums
Tx-Sx-FS
Car: S13 KA-T
ive seen that thread..i should have made it clearer..but i need the site for the people who sale those spark plugs..so i can just click "add to order" or "buy these" something in that order..but ill prolly just get NGK in stock order..if u can help then ill do that but if not then ill get stock...thanks tho
huguetpj
Car: 93 KAT Coupe
Google is your friend. Don't expect to have everything handed to ya.
NGK plugs @ clubplug.net
I have never dealed with them, nor do I know if this is the best price. But it is a start for ya. You can also see the NGK iridiums in the same page... but I'll leave that as extra homework :D
Just search for BKR6E-11 in Google.com
